Reset button pressed 20 times!!!
John@Reliable
Member Posts: 379
Took this out of an FHA today. Had to bring it home so the kids could have an old fashion "oil mans campfire" will return and reinstall it tuesday morning. Thank god the homeowner wasn't able to restart the system,homeowners wife told me reset was hit aleast 20 times. Took over 25 mins. to burn itself out. Anyway folk's this is why reset 1 time only! John@Reliable
Shoulda had some sticks and wieners...
for the kids!!!!!
Good thing that thing didn't light off!!!!
Can you say BOOOOMMMMM!!!!!????0 -
thats great
John,is the chimney and flue pipe oil soaked too? Had a gas station where 3 shifts reset the suspended furnace about every 20 minutes for 9 hours. I drilled 1/4" holes thru the case into the exchanger and drained it to a 5 gallon bucket.Had the fire deptment there when we fired it up the next day after I wiped out the case and flue pipe.Killed every bug with in 2 blocks.Forrest Gump lives in every state I guess. Dave0 -
LOL
I like the push the re-set 20 times part John! So true!!
Like...My tape deck ( we are old kids ) ate my tape.....So I stuck another one in..DOH! Then I.... ;-D0 -
Dave, I was lucky
only the heat exchanger was wet,nozzle was plugged but still had a flow but no vapor.Wiped it down reinstalled the chamber and lite off was good with no smoke John@Reliable0 -
is this an example
of "clean burn" technology? :-)
Mark0 -
That's one way to look at it I guess!
- 86.4K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 926 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
