Delco oil/hot air transformer
Doug_4
Member Posts: 1
Want to avoid a $180 replacement of transformer on this old unit (for now). One terminal is loose internally creating intermittent short. Looking for advice on its repair or direction to web-based source material on the heating unit in general.
Transformers.....
Are not repairable . For an less expensive repair , consider asking if your tech can get a hold of a "universal six-way" transformer and block the appropriate holes off for the time being . A Delco furnace is an old piece ! Save your pennies and do the right thing . I think the Smithsonian will be looking for that dinosaur for their collection soon ! Chris.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
