Multiple Tekmar remotes
bruce pirger
Member Posts: 111
I would like to install a Tekmar 063 RTU downstairs, as well as an R062 upstairs. Is it possible to connect both RTU's to a single 363 controller?
I'd like to have remote status upstairs...an R040 would work, but I'd also have to install a temp sensor next to it, as the R040 I believe is remote access only. Therefore, I prefer to install an 062 upstairs.
But can I install both the 063 and 062 to the same controller?
Thanks!
And thanks for the pointers fella's to the tekmar online sales sources!
Thanks!
You cannot do what you're asking. The 363 can only accept either an 062/063 for a single zone mixed demand OR an 040 for remote display. Not knowing the details of this system, one option would be to use tekmars new 510/511/512 series t-stats for the zones and the 040 for the remote display.
I thought as much...didn't know how the communications would work...which one first, etc. Didn't expect to have arbitration on a shared pair in home heating control...but I bet it's not far away!
Thanks for the help!0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
