Propane parlour heater sez,\"thup...thup...thup.\"
copperhead
Member Posts: 8
my new pad came equipped w/a Martin Industries parlour heater as it's main heat,(oh well..) replaced the thermocouple,pilot didn't stay lit. replaced the gas valve and got heat. i'm almost happy...except the burner goes,"thup..thup...thup..thup.",which is very annoying and doesn't give me a great deal of confidence in my sole source of heat. also seems to be a little delayed ignition. i cleaned the tube,perhaps not thoroughly enuff. any thoughts as to what's going on? i'm not a gas guy,oil is more my area of service experience. thanks ,
rk
rk
rk0 -
my new pad came equipped w/a Martin Industries parlour heater as it's main heat,(oh well..) replaced the thermocouple,pilot didn't stay lit. replaced the gas valve and got heat. i'm almost happy...except the burner goes,"thup..thup...thup..thup.",which is very annoying and doesn't give me a great deal of confidence in my sole source of heat. also seems to be a little delayed ignition. i cleaned the tube,perhaps not thoroughly enuff. any thoughts as to what's going on? i'm not a gas guy,oil is more my area of service experience,however,whatever needs to be tested or done i can do. thanks ,
rk0 -
Have your propane company
check it out. It sounds like the burner is not lighting correctly. Do you have a CO tester? If so make sure it is safe or leave it shut off until someone with GAS experience checks it out.0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
