Basics of System Bypass
Jeff W
Member Posts: 12
Basic question on system bypass--When piping a FHW boiler (CI rads) with pumping away setup (2 zones w/ circulators) should I take the bypass line off before the shut-off valve from the feed or right after it? Thanks...
Bypasses
PJ,
What you are referring to is in actuality a "Boiler Bypass" because you are trying to bypass the boiler with the system return water. This will account for proper system flow while reducing the flow through the boiler. Depending on where your pump(s) is, there are two piping methods as shown below. A System Bypass takes heated boiler water and diverts it back to the boiler return to keep the boiler warmer while reducing the flow to the system somewhat. We would most always call for a boiler bypass. Hope this helps!0 -
Bypasses
PJ,
What you really are referring to is a boiler bypass and not a system bypass. A boiler bypass is used to take a quantity of cooler boiler return water and divert it back to the system supply instead of through the boiler. Thus bypassing the boiler and devoting all of the system supply flow through the system where it should be. This will reduce the flow of cooler water through the boiler and will allow it to stay warmer.
A system bypass takes heated boiler supply water and sends a portion of it across the bypass to the boiler return to help keep the boiler warmer. A considerable reduction of flow may result through the system this way though. We would most always recommend using a boiler bypass as per the drawings below. Pump(s) location will change the way you pipe the boiler bypass. Hope this helps!
Glenn Stanton
Manager of Training
Burnham Corp.0 -
system bypass more appropriate
Since he has cast iron radiators (gravity conversion?) might not a system bypass be more appropriate?
Mark0 -
no bypass required with a Revolution, right?
some boilers, like the burnham revolution, have their own boiler circ pump and it acts like a built-in bypass0 -
Test
of Archive0 -
Radiators
do not neccessarily have to always be on a gravity conversion system. There are many radiator jobs installed with Venturi system layouts. If in fact his radiators are installed on a gravity conversion system with big old pipes, then a system bypass like the one below would be appropriate, otherwise stay with the boiler bypass. Hope this helps.
Glenn0 -
The Revolution
does not require a bypass because one is already incorporated into the boiler. This bypass in conjunction with a variable speed pump performing reverse injection keeps the boiler safe with return water as low as 55°F. Hope this helps.
Glenn0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 987 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
