Steamer in the cellar
Until you get closer .....
  • The door that leads to .....
    the middle of a staircase . A creaky , broken , leaning to the left staircase .
  • The steamer was a Slant Fin Malibu
    Still working good . The customer just wanted to upgrade before the famous burn-through these boilers have every once in a while .
  • Peerless ECT 3
    Easily split into 3 sections to get in the cellar , easy to reassemble , and a damn fine steam boiler . The other pic is of the return piping in copper . We use a full sized ball valve for skimming , and a ball valve and drain to clean out the returns . The last pic is of a line tap right into the header . Anyone ever use one this way ? This one was installed with the boiler - 30 years ago , along with alot of copper piping to replace risers - I checked all of it out and the solder joints still lokked fine after all that time .
  • kevin
    kevin Member Posts: 420
    very interesting...
    are there legs on those horizontal tanks? I have never seen the saddle taps before.Should have come off at a 45* though, right? That wasn'tast of basement stairs it was an elevator shaft!Nice work again Ron!
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    stress relief
    looks like someone took out their frustrations with a baseball bat on the side of that water heater :-)
    Mark
  • ScottMP
    ScottMP Member Posts: 5,882
    Dents
    Where ther in the before picture so we know it was'nt Ron. :)
    Nice work as allways Ron. Do you use new push nipples or is this rubber gaskets for the sections ? If push nipples do you coat them ?
    You still hav'nt sold me on the copper returns yet :).
    Nice work as allways. Looking forward to meeting the " master of install " this Nov.
    Scott
  • Yep , the Peerless has steel push nipples
    We see them coated from the factory with Rectorseal or a Teflon based sealant . We use Rectorseal on the same nipples - done it on hundreds of ECTs without a problem . We have also used copper returns on hundreds of jobs without a problem . After seeing what steel pipes look like after years of service , compared to what copper looks like , we are willing to take the minimal risk of using it . Thank you very much Scott , but I dont think my work compares to what you and Chris can accomplish . I am looking foward to meeting the both of you also . I will make a copper return believer out of you yet .
  • Those tanks had little stubby legs
    holding them off the ground . There was a common fill teed into the 2 tanks and separate vents for each . One tank didnt have the vant alarm in it - makes it extremely hard to fill. I never seen that tap used either , but it looked pretty good after all this time . Its a great idea for installing a main vent where you need one - if its a hard spot to add it . They didnt go on a 45 because it would have pitched the riser the wrong way - it was a long run to the radiator in a crawl . With all the mixes of copper and steel and the tees going off without 45s , the customer said she never heard a banging in the pipes . Thank you Kevin
  • That heater
    is in its 3rd house - the homeowner told us her sons installed it there after making the rounds in other places . Its seen better days though .
  • Dave Palmer
    Dave Palmer Member Posts: 186
    Ron, whats the Taco relay of the front?Switching relay?Looks good,Dave
  • ScottMP
    Hey Ron
    There is beauty in simplicity.
    Thats why I like your work, its allways plumb,true, and clean.
    O.K. How sick am I.
    Scott
  • John@Reliable
    John@Reliable Member Posts: 379
    Dave,
    bet to turn burner on. Nice work Ron! John@Reliable
  • Dave
    Like John said , its used to turn the burner on - the thermostat was low voltage . Matter of fact , Ive only seen one line voltage steam zone before . Thanks Dave .
  • Dave Palmer
    not...
    just two wires down too the relay on burner? Dave
  • The Riello burner
    doesnt come with a tradition cad cell relay ( T - T , and F - F terminals on the outside ) . You need to add a relay to make it work a steam system . Ive heard of the Riello with the built in T and T in the brain , but we havent seen it yet . It would have to be pretty cheap to beat the price of a single Taco relay .
  • Rich Huey
    Rich Huey Member Posts: 1
    Radiators / Push Nipples
    I have taken on the challenge of using hot water radiators in the addition I am building on my house. I have been collecting all the old radiators I could find and am now in the process of restoring them.... I did what not seems to be the unthinkable and seperated the fins on some of the radiators. Now I am in the market for some new push nipples. I have looked everywhere... and have found none. Any advice on where to look next? Can I have them made to fit? Can I make them? Are there old design criteria and manufacturing data out there somewhere? It also seems that I need a tool to squeeze the sections back together... Does anyone know where I could find/barrow/buy such a tool? Any advice would be greatly appreaciated. I am a longs ways down this road and will not stop now..... Thanks Rich
  • I've seen a guy that used the old push nipples and a LOG SPLITTER to put the sections back together.
    Yes, I said log splitter.
    I ran into the Riello/steam problem last night when I realized there was nowhere to put the thermostat wires.
    Good thing I keep a Taco SR-501 in the truck at all times.
    Supposedly Riello has fixed this "issue" and has a 24 volt primary.
    We've done many water jobs with Riellos, and I never noticed that the TT was not there. Maybe I'm just getting old...
  • Malibu Burn thru
    What is the burn thru? The dry base combustion chamber? Any preventative maintenace to head this off?
