QB-180 Burner
Leon
Member Posts: 14
Any opinion on weil-mclain burner QB-180.Pro and con.
Re: QB180
Not a bad burner but at least IMO not quite up to Riello standards. The biggest problem with this burner is the fact that it has been discontinued.
jcg0 -
I don't believe
that WM is even making them anymore.
Mark H
QB W/Mburner
I installed a few 3-4 years ago . They said (at the supply house) it stood for "quiet burner" . Couldn't be further from the truth .They were loud running , loud starting and loud going up the chimney . Ran nice and clean , but the noise drove me back to W/M-Beckett combo with pre and post purge . JMHO Chris.0 -
Ran nice............
until they did'nt... when those babies start runnin funky the boiler turns into one nasty soot ball.
Frank0 -
True, and at that point you probably replaced the
spinner and it went back to running fine. I have never heard of it, but I wonder if the air holes in the brass ring could become plugged given the right environment.C0 -
After doing this for ,
about 10 years I think anything can and will get plugged!I have found the W/M with an Carlin E-Z Pro burner will give you very nice results.0
- 87.5K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 169 Indoor-Air Quality
- 15.9K Strictly Steam
- 57 Water Quality
