angle raditor valves
b.phillips
Member Posts: 2
what is the difference between steam and hot water angle radiator valves? i have been told that you can use steam valves on hot water systems but not water on steam. is this right?
difference
Hot water valves are not a complete shut-off valve, there mainly for balancing, even when turned off they will let a slight flow through them via a small hole drilled either through washer or butterfly.
Steam valves are simliar to globe valves with a large washer which you can have a possitive shut down
Yes, you should not use hot water valves on steam systems because they will not operate properly
Be careful as i have seen steam valves that they drill a hole through and use as hot water valves, N/G for steam. they will not shut off.
hope this helps, Ant
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 85.8K THE MAIN WALL
- 51 Biomass
- 419 Carbon Monoxide Awareness
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 860 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 40 Industry Classes
- 16 Recall Announcements
