Boiler gauge placement: The manufacturer of the Buderus boiler I
![Joe_30](https://secure.gravatar.com/avatar/ffdd7769ebae4e4edbd204022db5b786/?default=https%3A%2F%2Fvanillicon.com%2Fb6535d3e245298266723592d66749e4f_200.png&rating=g&size=200)
Joe_30
Member Posts: 85
Can I put a boiler gauge at the top of a 12 inch stub of a pipe, coming off a tee in the horizontal supply water pipe.? I would have a bleed valve to get rid of air. It's would not be in the "flow" but the temperature and pressure should be the same. [ The manufacturer supplies an elbow and a vertical header with the gauge inserted right into the flow, but I am not piping in that upward direction.] Geez, I don't liker boilers with the piping at the rear. Thanks, Joe
The installation instructions for the Buderus (well, at least the one I have) shows that the header they supply can be mounted vertically or horizontally. Personally, I'm planning on leaving it vertical and then taking a tee off that to get around the exhaust flue and meet up with the air seperator. The tee will also make a great spot to install the low-water cutoff as it will be above the boiler.
Just a thought.0 -
the pressure
would be the same, but I would expect the temperature to be a lot lower.
Bill0 -
Boiler gauge on-a-stick
Reply to Bill: If the boiler gauge is on a 12 inch high, 3/4 inch pipe rising off the boiler supply outlet point, and has a bleed valve to remove any air, and has a little insulation on it, won't it give a good temp readout, with a tiny lag time for changes? What am I missing. Water is a heat medium.
With our the supply line running straight back from the boiler, nine inches below the top of it, a gauge in- the- line would be sort of down out of view. So, a gauge on a little stem SEEMS to be an answer. Joe, a cautious amateur.
- 85.8K THE MAIN WALL
- 51 Biomass
- 419 Carbon Monoxide Awareness
- 75 Chimneys & Flues
- 93 Geothermal
- 150 Indoor-Air Quality
- 3.3K Oil Heating
- 59 Pipe Deterioration
- 860 Plumbing
- 5.8K Radiant Heating
- 375 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 40 Industry Classes
- 16 Recall Announcements
