Pressed fittings
Steve Ebels
Member Posts: 904
Are there any brands of pressed fittings other than Ridgid available here in the U.S.? I know there are literaly hundreds for all kinds of tubing over in Europe from looking through my REMS pipe tool catalog. Stuff for copper, stainless, aluminum etc. The distributor that supposedly has the exclusive rights for Northern MI. doesn't stock very much and I'm looking for someone who does or for another line entirely.
HMMmmmmmmmm. Maybe I'll have to start importing some and match them up with some of that REMS equipment.
victaulic makes
a system that works with light gauge steel, they call it press fit. I have used it , the tool is similar to the pro press. I have not priced it in quite a while, but would rate it as good as the copper.
Paul.0 -
Pressfittings
should be more available within 6-12 months. Mupro/Rems would be a good source or Schlup fittings in CA. I'll be checking out ISH-NA for who will export other other lines besides Ridgid/Viega
Weil-Mclain has pressed fittings
for Alumipex. C0
- 86K THE MAIN WALL
- 52 Biomass
- 420 Carbon Monoxide Awareness
- 80 Chimneys & Flues
- 5.3K Gas Heating
- 95 Geothermal
- 154 Indoor-Air Quality
- 3.3K Oil Heating
- 60 Pipe Deterioration
- 888 Plumbing
- 5.9K Radiant Heating
- 378 Solar
- 14.7K Strictly Steam
- 52 Water Quality
- 41 Industry Classes
