Gas flame vs. oil flame
servicewiz
Member Posts: 7
I know that #2 fuel oil burns hotter than Natural gas but have never seen the actual temperatures.Any info. or resources I can look into on this topic? Thanks for any help!!!!!!!!!!! JVS
btu's
I don't remember what it is for natural but lp gives you about 94,000 btus per gallon where oil you get about 145,000 btus per gallon.
Joe0 -
Those are btu content
Numbers. Natural gas is 100,000 per therm, which is 100 cu.ft. I think I've seen #2 oil listed at 139,000/gl and LP at 93,000/gl.
I think what he was asking is if there is an actual difference in the temp of the flame. I don't know the answer to that. Maybe Timmy or someone really smart on that stuff does.0 -
Gas Flame Temperature
The Gas Engineers Handbook list a Natural gas Flame as having an average temperature of about 2800 degrees (F). I will have to look up oil flame temp. I will probably ask Alan Mercurio or George Lanthier I am sure they would know. Is there a particular reason you wanted to know?
Just a little point of info, before mid efficiency and hi efficiency gas systems oil power burners were more efficient than gas atmospheric systems. Why? Simple the oil power burner used a motor therefore it needed less excess air about 20% versus the gas atmospheric needed 40 to 50%. Then again the Gas Power conversion burner installed to replace most oil burners would give about 78 to 80 % Combustion efficincy.
Another difference is the ultimate CO2 of the two fuels natural gas is 11.7% oil is 15.2% this sometimes causes people to confuse the efficiency concept as gas is typically 8.5% to 9.5% oil can be up around 12 to 13%. they are actually at that point about the same efficiency.0 -
if
foggy memory serves, gas flame is around 1700-1800 degrees and oil is 2400-2500 degrees.
See
I knew there'd be somebody really smart here.
Thanks Bob & Timmy0
- 125 Chimneys & Flues
