Couldn't believe my eyes! (Steamhead)
Steamhead
Steamhead Member Posts: 17,628
before she bought the house. She really didnt remember, but the important thing is getting it straightened out- which we'll do.
If the system was that way when she bought the house, I wonder if she had an inspection done and if so, whether the inspector caught it.
There's a lot of sloppy work in that house. But that's why we're here! ;-)
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
    Found this today
    Owner was complaining about noisy baseboards. Can you see why?
    Yes, the picture IS right-side-up.
    Consulting
  • Jim Sarrasin
    Jim Sarrasin Member Posts: 10
    LOL
    love the wiring job too.
  • chuck shaw
    chuck shaw Member Posts: 584
    someone
    probally read the directions....need at least 18" of pipe before the pipe seperator....then went to lunch, and that is all they could remember when they got back....
    gotta love it
    Chuck Shaw
  • Chris_4
    Chris_4 Member Posts: 75
    love the soldering job too!
    I am getting a digital camera this week, you wouldn't believe the stuff I have been running into.
    its a shame that there are those that install equipment like this, and have NO CLUE what they are doing!
    Chris
  • keith
    keith Member Posts: 224
    How this stuff happens is beyond comprehension
    If this doesn't bring a tear of joy to your eye I don't know what would. What was the story you heard after the laughter subsided?
  • hr
    hr Member Posts: 6,106
    Hey, that guy gets around
    He spent some time in Missouri :)
    hot rod
  • todd s
    todd s Member Posts: 212
    But
    The arrow is pointed in the "up" position.
  • John@Reliable
    John@Reliable Member Posts: 379
    But,the guy at home depot said it would work!
    you guys are so picky haha
  • Cosmo
    Cosmo Member Posts: 159
    uh....
    The phrase "why bother" is quite at home describing that air scoop.....in my area nobody can afford to use valves to isolate the boiler, and or other components.....but they can afford to watch me wait for a four story converted gravity rad system empty just to replace a circ.
    Casmo
  • Floyd
    Floyd Member Posts: 429
    not to mention....
    bleeding all those rads when you fill it back up :-)
  • wethead widow
    wethead widow Member Posts: 5
    cheer up !
    at least the flow check is in the right position, and the circ. motor isn't pointing straight up.
    Paul
  • Floyd
    isn't that a 110 circ.???
    bigger really is better... isn't it????
    bet that water really sings!!!!!
    That system is really screwed up
    the same lack of intelligence appears in other parts of that system. Stop/waste valves on the loop returns, purge valves installed the wrong way, and a total of 3 3/4-inch loops coming together into a 3/4" return line!
    The lady wasn't sure who did what, but I told her we'd make it work properly.
    Yes, that is a Taco 110 circ. After years of straining to move the water thru that screwed-up system, the seal started leaking, which is why we were called. I'll probably put a 0010 on when we repipe it- Pumping Away of course.
    Consulting
  • Boonierat
    Boonierat Member Posts: 58
    Steamhead
    A grown man doesn't deserve this much entertainment all in one shot.................way, way too funny.
  • JimGPE_3
    JimGPE_3 Member Posts: 240
    I keep a file called "things I've never done" and this is going in it. It will sit next to my current favorite, the photo of the mitered light switch cover plate. The switch was close enough to a corner in the wall that the contractor cut the switchplate, mounted the "extra" part on the angled wall, and caulked the joint!
    Amazing stuff.
  • Earthfire
    Earthfire Member Posts: 543
    engineered excellence
    That gas line is a work of art too! Oh well gas is dangerous ,it blows houses up for no reason. At least somebody was lubricating the circ.motor.
  • Dale
    Dale Member Posts: 1,317
    The vent piping
    is my favorite. I wonder if the manufactuers literature showed an elbo right on top of the jacket. Sadly, there's plenty of room for a 2' connector rise if the knowledge had been there. Of course the vent hanger "system" he used is also worthy of my "good bad example" file along with the invisible union and dirt leg on the gas line. Truely you can't make this stuff up.
  • Roger Litman
    Roger Litman Member Posts: 64
    Why did the homeowner use this contractor?
    I've run into this type of work once in a while and a local man was often doing the work. When I asked why the homeowner chose this contractor, I was told that he had a number of prices and he picked the cheapest. This happened from two different individuals, so while I have a lot of sympathy for people who pay a fair price and look for a reliable contractor, I think that some people get the job that they deserve and are willing to pay for.
  • whats up with the waterheater flue pipe also
    yup, the boilers is a piece of work, the waterheater flue looks weird also, is it going into a smaller pipe on the left end or is it just an optical illusion thing? looks to long to vent right...nice hangars on it also....not..hehe
