taco question
chuck shaw
Member Posts: 584
Does anyone have a tech support number for Taco? I am having a problem with an ESP valve. It will cycle its self thru one complete revolution, about every ten minutes, without a call for heat. When it does this cycle, it does not fire the boiler, when there is a call for heat, it works fine.
thanks,
chuck shaw
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=143&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
thanks,
chuck shaw
Did you check
the amp draw of the thermostat? Some of the power stealing type require the use a resistor.0 -
phone number
taco phone number is 401-942-8000
web site is www.taco.hvac.com0 -
Taco ZSP Aone Valve
Give Chris Integlia a call at 1-401-942-8000 or e-mail him at chrint@taco-hvac.com and he will help you out.
John Jr0
- 87.4K THE MAIN WALL
