lead free solder & acid free flux OK?
Mark Woodhouse
Member Posts: 4
I understand lead free solder has a higher melting point, so required more heat. Are there any reason why it shouldn't be used in hydronic heating?
If anything,
lead-free solder should make for stronger joints. No reason why it shouldn't be used for hydronic.
We use Bridgit lead-free for heating and plumbing becuase lead is extremely toxic and I don't want my guys handling it.
Lead free solder
There are different types of lead free solder. 95/5 will melt at a higher temperature, but the newer solders which contain silver actually melt and run (sometimes) like a 50/50 lead containing solder. You need to try different brands/compositions to find the best for your job. I have actually tried several different brands that stated the same composition, and found some worked better than the others.0
- 86.4K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 925 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
