primary/secondary boilers- jim f.
JIM F.
Member Posts: 82
just fooling around with sizing my pictures. here are 2 burnahm 8 section boilers piped primary/secondary. this was my first prim/sec job. a lot of research went into this one. the primary loop is about 250' of 2" black with 3 seperate mechanical rooms srategicaly placed around the house. there are 9 hydro-air systems,3 garage unit heaters and an indirect tr-100 phase 3. the sub picture is the primary pump on this system. i do need to learn more on some modern operating controls. the main pump is operating on a outdoor t-stat set at 62*. the 2 taco 007's on boilers are operating 24/7. being i did not price this job, no for thought was put into controls on the original bid(against my better judgement). any way it is what it is. this system is a glycol system at a 60/40 mix. i can't remember off the top of my head but i think we put in about 75-80 gallons of glycol. this job was located in greewich, ct. and the house is approx. 13,000 sg ft. going for 4.5 million dollars.
jim f.
milford ct.
jim f.
milford ct.
- 87.4K THE MAIN WALL
