circulator sizing
mike terry
Member Posts: 33
well its almost time to start my floor heat system.its a staple up job with heat transfer plates. the tounge and groove flooring is 3/4 of an inch and put right down on the joist.no subfloor...bt the way the tubing diameter is 1/2 inch. and there is a layer of r19 insulation under the tubing/plates. because of the open floor plan and the fear of expansion and contraction noise.im gonna run this on constant circ/reset.so what i have is 4 circuits each one is 250ft long...a little long i know but couldnt help myself.so i wanted to run these 4circuits in a loop and use an injection pump from the primary loop. what size pump would you need to circulate the right amount of water thru those 4 250 circuits? and how does one figure the size of the injection pump? thanks....mike terry
Circ
B&G NRF22, Taco 007, Grundfos 15-42 will all work. What is your primary temp. and your design temp. for your plates & tube?0
- 86.5K THE MAIN WALL
- 53 Biomass
- 94 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 156 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 927 Plumbing
- 6.1K Radiant Heating
- 383 Solar
- 15.1K Strictly Steam
- 41 Industry Classes
- 48 Job Opportunities
