Question about adding a steam radiator
Stuart
Member Posts: 3
I have some sections with two-pipe, some with one-pipe, radiators. I plan to add a radiator to a section in which the other radiator feeding off the same source is two-pipe, although on the second floor. The radiator I'm adding is on the first floor. Do I also have to have the contractor set it up as two-pipe, or will one-pipe work?
Thanks.
Thanks.
I'd stick with 2-pipe
since the steam main in the basement might not be big enough to handle the additional condensate from a 1-pipe rad.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 917 Plumbing
- 6.1K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
