equalizer
kevin
Member Posts: 420
hi guys, is it possible to oversize an equalizer in a steam system? The supply header is going to a 2 1/2"main and the equilizer is recommended by the manufacturer to be 1 1/4" going back to the return. Would there be a problem running 1 1/2" instead? Would it be better? T.I.A. kpc
equilizer
steam goes up and water goes down, in my opinion, i wouldn't think this could be a problem.---AL0 -
It's OK
to make the equalizer bigger than minimum.
Noel0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.7K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 772 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
- 19 Recall Announcements
