Entran II
Matt_4
Member Posts: 1
I'm considering buying a house in the mountains of Colorado that has in floor radiant heat. The tubing used is the infamous Entran II. The house is 10 years old and 3300 square feet. The tubing is encased in concrete but all manifolds are accessable. I just had a plumber inspect the system. It appears that the tubing at the manifolds is still soft and flexible, has the oringinal orange color and is not leaking with the exception of one small leak in the garage. I had the plumber take a sample of the glycol/water solution to analyze. The fluid was a brownish/black color but had the consistancy of water and smelled like anti-freeze.
The tubing has the following markings:
-Entran II Heatway Systems UPC 2774
-See Boca Research Report No. 87-51
My questions are:
1. Should I buy this house?
2. Is all Entran II doomed to failure?
3. Are there good and bad batches of Entran II
4. If I buy the house should I immediatly retro fit it with a new system?
5. What things should I look for in the system before deciding to buy?
Any help would be greatly appreciated! Thanks!
My questions are:
looking into my crystal ball!
depends. What is the date code? Spring 91 is a risk. Operating temperatures? Jacket color. Retro fit possibility, just in case. Do you feel lucky? Certainly a a bargining chip.
hot rod
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.9K THE MAIN WALL
- 57 Biomass
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 970 Plumbing
- 6.3K Radiant Heating
- 386 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
