Pole barn radiant system
Tom Bradd
Tom Bradd Member Posts: 34
1" is ok but can you try to get more on the outside ? even dig down prior to foundation you can install the insluation on the outside of the wall as well.. Good Luck
  • Al_3
    Al_3 Member Posts: 79
    Any opinions on properly insulating underslab of a pole barn
    type constructed building, specificaly perimiter insulation?
    Building is new construction, R-19 walls, R-38 cielings,
    48'x60'x12' with he-pex radiant system. If I used 2" foam
    underslab & 1" perimeter foam only the thickness of the slab
    ( 6" ) instead of possibly going 2' deep with the perimeter
    insul, do you think I would have a much greater outward loss? In other words, do you think I would have a beauty of
    a flower garden around the structure in mid january in the
    northeast????????????? Thanks AL
