Have You Ever...Calif.Radiant
Alan(CaliforniaRadiant)Forbes
Member Posts: 1,243
Have you ever had a leak in a system that was real hard to get to, or perhaps you didn't have time to fix it? It's usually a small leak; about a 15 minute fix except for the fact that you have to drain the system and then purge it; that makes it a 2-3 hr. job.
I just saw this product at a wholesaler BBQ; claims that you can fix a leak with the pressure on (up to 30 psi) and it's good up to 5,000*F.
I don't know about you, but I've got a few systems that I see that have small drips from threaded fittings or bad solder joints that are a pain to get to.
Link:
http://www.nucalgon.com/nucalgon/nucalgon_products.nsf/All/B05D2A6558AD609486256B9E001FBE5E?OpenDocument
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=53&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Link:
