Weil_McLain WGO-3 cleaning brush?
Mark R.
Member Posts: 40
Does anyone have suggestion for a good brush for cleaning Weil-McLain WGO boilers. I recently used a brush that is about 3/8 - 7/16" diameter, but the spiraled wire shaft was a problem. The shaft diameter was to large. Is there a special brush designed for this series of boilers. I would appreciate any suggestions.
Thanks, Mark R.
Thanks, Mark R.
shop
around for a thinner handle,they do make them.And buy a tool called a soot sword it has a long narrow blade to fit between the pins.Just remember to brush on a angle and not straight up and down or it will get stuck and your brush should easiery fit0 -
GO brush
Try a Mill-Rose cat.# 84009 it's made for Slant Fin but works great for W/M, Burnham , etc. Looks big but it will do the job! Hope this helps!0 -
Thanks John & Dave
Thanks for the help with a brush for the W/M. I will try to get one or the other of them. I thought there would be a better brush than them one we used. I really appreciate your help. Mark R.0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
