manifold
JIM F.
Member Posts: 82
another boiler manifold
secondary???
Jim,
why the 011 or 012 on the far right of the photo? Asking not seeing where the pipe is going.
Very very nice!
al0 -
> Jim,
> going. Very very nice!
> al
> Jim,
> al
that is a taco 0010 supplying a phase 3 indirect hot water heater.0 -
the taco 0010 circulator is supplying a phase 3 indirect hot water heater0 -
Phase 111
Jim,
Thanks, must be a big one.
al0 -
PHASE3
THIS WAS A MODEL TR-75. WE USE A HIGH VOLOCITY CIRCULATOR FOR BETTER RECOVERY RATE. HAD PROBLEMS WITH THE PRIORITY FEATURE ON THE ZONING CONTROLS. LOSING SOME HEAT LOAD DURING THE PAST WINTER. I THINK THE TANK WAS UNDERSIZED FOR THE APPLICATION. WE ALSO FED THE PHASE 3 WITH 1 1/4 PIPE. SHOULD HAVE BEEN AT LEAST 1 1/2 ACCORDING TO MANUFACTURE. ITS BEEN WORKING WITH NO PROBLEM. WE DID NOT DO THE DOMESTIC WATER PIPING.0 -
Beautiful work Jim
I am becoming a believer in those speed headers after every pic you post . I think someone mentioned a multi zone control that has a time limit of how long the priority will run by itself - I forget the brand though . Great looking job . Ron .0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
