Cousin's House photos Bill N
Bill NTSG
Member Posts: 321
Boiler---oops! I will work on it.
Photo?
Billy,
Time to check with the u know who guy.
Bill click add to get the picture to the post
al0 -
lets try.......
this
formage:)0 -
Thanks Cheese
That spaghetti pex is not mine. My cousin [the carpenter]gets credit for that0 -
carpenters................
whatta they know about heat......eh?
cheese
PS nice job Bill!0 -
inquiring mind ?
It seems to me looking at the pic "climate panel. jpg" That the supply water piping to the manifolds is small compared to the circuits attached to it. That is, under full load that the supply piping may not allow enough flow through to do the job. I look at piping this way, A 1" pipe carries the full load of 4, 1/2" pipes. You can draw 4, 1/2" circles in a 1" circle. Now of course you can get pumps that will force the situation, but is that practicle? Also why do the manufactures of the manifolds have large pipe in them, when only smaller pipe is used to supply the manifolds? I usually try to keep my flows at 5 feet per second. This is usually followed keeping the diameter as I described above. Larger pipe can be mathetically calculated to allow more connections than the 4 into one ratio. 5 feet per second is a nice flow that auto valves like to operate against. It turns out that as we go above that velocity water hammer due to quick closeing valves becomes prevelant. Not to mention turbulance corrosion. Anyway I perhaps need to be clued in! bigugh0 -
Big
Maybe it should have been larger. But it works, it is just floor warming and the tubing is 10.5mm or now called 3/8"nom. . One of those circuits is a small bathroom that only has a heated area of about 3' x 5' . Those are zone valves [NOT my idea ] and hopefully will be open all of the time. The design temp. for the coldest day is only 127-130°. It is all hardwood and some vinyl over plywood. No rug . The garage floor is heated off another panel. The CI radiators came out of an old farm house and were stored in a hay trailer for 20 years. I helped with the entire house from foundation to finish in exchange for a pig. Bacon,sausage,ham, etc. All of the drainage and most of the domestic water and heat pipes are below grade and insulated where possible. Did you notice the misapplication of Wirsbo fittings on the Stadler tubing? This was really a budjet job, not a lot of money. The boiler was discontinued old stock and I got a good deal. My cousins ran most of the tubing. [All of the straight runs were mine] It is a very comfortable home. He has a 3 yr old and one on the way. I hope they grow up and want hydronic heat.0 -
SEE ? What I see is, that I cannot believe my own worn out eyes. I said I was inquriring what was going on. I did not intend to criticize your work, but to increase my own knowledge. And I did that! Thanks again. That is a nice job. bigugh0 -
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 60 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
