ELECTRIC BOILERS
Steve Eayrs
Member Posts: 421
I have only done one electric boiler in the last 15 years.
Have a customer, who wants to go electric, w/plans for solar panels, wind generation, etc.... Not the usual for us, since we have high KW costs.
Have you found any brand better than another?
Thanks in advance, Steve
Pretty much the same
If you want cast iron Slant Fin, Weil, and Burnham are all brands I have used. There are some steel versions, I used EFM and Argo. Basically they are all a tank of water with electrical elements and contactor/ sequencers. Not a lot of differences between the actual components.
And there are some interesting modulating electric instantanous models out there Seisco (plastic) These are not usually ASME stamped as boilers however, as the cast iron models are.
hot rod
electric boilers
We have used a few Argo boilers. The issues I've seen are- use a good means of air elimination and make sure you have good flow. If you have multiple zones make sure you use a pressure bypass or primary/secondary piping to keep the flows up. I've heard they can burn elements from too slow a reaction time when flows drop. PS don't let the sparky dry fire it.0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 990 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
