cutting threaded rod
Anyone know of a tool specificly for doing this? Something that is quick and will not leave a burr? Thanks
You didn't
say cheap so I'll tell you we use a "Dry Cut" chop saw; they quickly cut almost any material without leaving a burr. We have one made by Porter-Cable (model 1410); DeWalt makes a quality one as well.
Also on the \"not cheap\" track...
When Mr Milne bought the new threader , the rep from REMS put a flyer in about a new(?) threaded rod cutter .(see "electric threader" thread)
Maybe he's got an email address you can get ahold of . Chris.0 -
I tried the REMS
all thread cutter at the ISH show. If you cut a lot of rod this is a must have. I could even cut 1 inch long pieces in half! It left the threads in perfect condition. Very portable and doesn't require a plug or extension cord
You could use this tool up on a scaffold even.
hot rod
thread rod
you can use a sawzall to cut rod. put two nails near end of 2x4 to hold rod tightly, or vise or foot. If you get any threads bruised use a thread file or thread chaser to fix. I find that holding the rod tight as close to cut as can gives good cut even with hack saw.0 -
cutting rod
the best tool we use is a panasonic metal cutting circular saw with a carbide blade it cuts rod sturt,metal pipe,pvc angle iron all like butter with out a burr and it cordless 14 or 18 volts lot of cut i have use it to cut open access holes in duct work sprile pipe no problem just litte noisey copper pipe no burr like you cut it with a band saw blades little pricey but well worth it jeff0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
