Monitor boiler
Chris_5
Member Posts: 1
Hello fellow radiant and hot water question and answer people! I have a sales person from one of my wholesale houses wanting me to put a Monitor high efficednt boiler system in a new home I am just getting started on, I have never used a Monitor system befor(have seen them in shows and at Wirsbo, but never installed), I have infloor(under concrete), staple down in the bathrooms and quick track in the kitchen and family room, this is a larger home. The boiler will be mounted on a center wall in basement with a new style vent system to be able to vent up a 2 story home? I am looking for input on this boiler in this application(I would use a Munchkin on a normal basis in this situation, but am looking a the Monitor) any input would be appreciated.
I have ...
never used one yet but I hear they are quite nice. Near zero defect rate. I'm sure you will get more input from others. kpc0 -
Matthew Connolly...
..is likely to find your post here anyways, but if not...
Matthew Connolly is your MZ advice man.
mailto:mdconnolly@enter.net
Also, if you have not already found this:
http://www.mzboiler.com/
and perhaps your install venting question is answered here:
http://www.mzboiler.com/contractors/manual/index.shtml0 -
A Cadillac
of a system; we've installed 6 of the MZ 25C's; very few call-backs; actually 2. One was for a bad hight limit and the other was a leaking auto air vent. Other that that - nada; and that's not bad for 6 installs.
You won't be able to use a B-vent though (acidic condensate) and there's a maximum distance for the balanced flue since it's power vented and the fan can only push so far. Better to find a room with an outside wall.
Drawbacks? There's a bit of a learning curve and the instructions are terrible.
Best wishes,
Alan
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 87.4K THE MAIN WALL
