Pinnacle Boiler
Mark Hunt
Member Posts: 4,908
one installed. A 199. We couldn't get a Munchkin so I put the Peerless in.
Of course it's just a Munchkin with a Peerless jacket and it is working fine.
We have got a little over a dozen Munchkins in service as well and have only had problems with one unit. It had a pierced pressure switch and then the gas valve wouldn't modulate down. Made a neat back fire when it tried to drop into low fire. Replaced the valve and it's been problem free ever since.
Don't be afraid to use the Pinnacle. I would recommend getting familiar with the burner set up. It is done by CO readings so you will need a CO analyser.
Hope that helped!!
Mark H
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=238&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Hope that helped!!
Mark H
Has anyone installed a Peerless Pinnacle boiler or had any service experience on them?0 -
I also used
one in place of a Munchkin. It is the same boiler with a different jacket. I like them a lot. You need to make sure you size the pump properly. There is a pressure drop across the heat exchanger. I tell my supply house that they need to stock more than a 007, it drives me up the wall.
Read the instructions and follow close and you will love the little bugger.
Good Luck,
Joe
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.2K THE MAIN WALL
- 52 Biomass
- 88 Chimneys & Flues
- 5.3K Gas Heating
- 99 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 910 Plumbing
- 6K Radiant Heating
- 380 Solar
- 14.8K Strictly Steam
- 53 Water Quality
- 41 Industry Classes
