Newbie Steam Question
Hi, I've got a question about my residential steam heating. My house is about 100 years old, with a steam heating system. The furnace/boiler is relatively new. I've got radiators in nearly all the rooms of this 2 family house, and I live on the first floor. Our tenant on the second floor has no thremostat, since the only one in the house is in our unit.
Since we have a wood stove downstairs, when it really heats up, it trips the sole thermostat, and then no heat goes upstairs. This is a problem.
What kind of options/what is involved in creating a separate "zone" to have the heat upstairs controlled separately? Everything I have read leads me to believe that the heat in the house is either ON or OFF, and there isn't really a simple way to control separate "zones" easily.
If there is a way to do it, what kind of $$ (ballpark) are we talking about to setup a separate zone?
Other solution ideas?
Thanks much for any help!
-Dan
  • parity
    Try putting the thermostat upstairs. This you can probably do for close to free. Splitting the system would cut into your rental profits for a many a month.
  • steam problem
    kent is right easeast way move tstat or spend money on outside reset and themostatic radiator valves best thing to do go to find a contractorat this site and find a company that knows steam systems good luck
  • Thanks
    Thanks Ed and Kent!
    With the easy thermostat solution, can I just add a thermostat upstairs and gang wire it in with the current one? This way, if either one trips, the heat will go on. Or do I need to actually move the one from downstairs to the upstairs, because you can only have one?
    Thanks again!
    -Dan
    P.S. - This site is great!
  • one thermostat
    Your tenant is the cold one, therefore let him have the only thermostat. If you have two, your's will probably always be off. If, after a week with his new power, you still notice windows open up there, it's time to talk.
  • tstats
    i agree with kent
  • How about....
    eliminating all the internal thermostats, incorporating an outside thermostat and putting TRV's on all the radiators.
    Just thinking outside the usual BANG BANG box here...
    There are a number of steam cycle controls that would be of a great assistance in this scenario.
    ME
