Weil McLain and Home Depot
Sparky
Sparky Member Posts: 1
As with most things Home Depot this applies. Weil Mclain is not what it was. Their Gold series leaves a lot to be desired. In an attempt to increase efficiency they slammed the sections closer together then had to redesign because they were too tight. They are still too tight in my opinion. Also don't forget that they have had problems with failures on the front section in the area of the top hinge. And don't forget those neoprene gaskets instead of pushnipples. Can't count how many steam boilers have failed at this location. Of course this is all IMHO!!
