Hot Water in Steam Radiators
George_3
Member Posts: 1
Our Co. has been hired to remove and dispose of up to 15 1906 american radiators of varying heights and lenghts. The boiler being used is a Franklin Prox Co. Economic 105 dated 11 30 5. Question to all, we hate to throw these items away so is there anyone who would appreciate these old things or are they just something that is past its age.
System was running last heating season. Yet here in south Texas we dont have many cold days. Also boiler appears to have been coal fired and has been converted to natural gas.
If I install an old-time steam radiator in a 180 hot water system, how do I figure out how much heat I get out of it. It's for an old historic New York Central train station job. Advice is appreciated!
Ted S0 -
Output
First, make sure that they are not "steam only" rads. These have connections across the bottom ONLY.
"EDR" (available here at Books & More) lists surface area of many, many rads. Knowing the surface area is key to computing the output.
For a good guess, reply with type of rad (column or tube); height, width, number of sections, number of columns (tubes). Manufacturer is often cast on the rad--often in original plugs or an the end section.0 -
Hot water/sream rads
http://www.colonialsupply.com/resources/radiator.htm
Cut and paste this into your browsers address bar.
Jim Bennett0 -
bad email
George, tried to send you an email but it came back no such account on flash.net0
- 86.3K THE MAIN WALL
- 53 Biomass
- 90 Chimneys & Flues
- 5.4K Gas Heating
- 100 Geothermal
- 156 Indoor-Air Quality
- 3.4K Oil Heating
- 63 Pipe Deterioration
- 916 Plumbing
- 6K Radiant Heating
- 381 Solar
- 14.9K Strictly Steam
- 41 Industry Classes
