What is this?
Vapor? Vacuum? Pneumatic control?
http://cgi.ebay.com/ws/ebayISAPI.dll?MfcISAPICommand=ViewItem&item=912201650&indexURL=0&photoDisplayType=2
  • This content has been removed.
    Steamhead Member Posts: 17,387
    Gas-fired radiator
    now illegal in most cities because it's unvented, and can set the curtains on fire. Probably made by James Clow & Sons.
    Consulting
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Scary
    I don't even trust "vent-free" gas logs with oxygen depletion sensors.
    Wasn't thinking of buying, just wondered what it was.
    Thanks!
    I bought one once
    just for the heck of it- was only $20 or so- never gonna hook it up, but it'll be a great museum piece once I clean it up.
    Consulting
  • Edward A. Carey
    Edward A. Carey Member Posts: 48
    Gas fired rad
    You know something, this is what I love about this forum. You never stop learning.
    After over 30 years in the HVAC industry, I have seen a lot of very strange stuff, however I have never before seen a gas fired radiator.
    I see a steam type vent, and what appears to be the air shutter. Could someone elaborate a bit on how the gas rad generally works, pilot assy, gets it's water, temp control, etc.
    Thanks in advance,
    Regards,
    Edward A. Carey
  • Jerry Sienfeld's apartment
    uses these radiators on TV. You put an inch of water in them and check it for water every other week. Run it like a space heater, turn it on and off as needed. They ran up to 5 psi steam, and modulated the flame back at 5 lbs. steam pressure.
    Seems to me that it disperses radiant heat better than the small flame by itself. Otherwise, it seems exactly like a direct fired gas heater, 100% efficient.
    Noel
