Indirect water heater to steam boiler question
GW
GW Member Posts: 5,137
Can anyone forward me a diagram to do this? I did it twice in the last 13 years, certainly my notes are gone by now... Thanks,
Gary
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=171&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Gary Wilson
Wilson Services, Inc
Northampton, MA
gary@wilsonph.com
  • joe_14
    joe_14 Member Posts: 138
    check out
    dans book How Come it gives all the info you will need to do this
    good luck
  • Any problems
    running steam boiler water through an indirects coil ? Has anyone found that they line up with crud ? Any special piping arrangements to flush out the coil ? Would the Phase 3 tank in a tank design be better suited for steam ?
  • ed wallace
    ed wallace Member Posts: 1,612
    steam and indirects
    I have a copy of Geoge Lanthiers book titled the hot water handbook it shows a drawing of the supply to indirect just below the water line in boiler than a check valve follwed by a union near the indirect than on outlet of indirect shows a union followed by circulator than return to boiler near bottom of
    boiler did indirect to steam boiler 3 years ago followed this drawing have had no problems if you need a copy of drawing will be happy to fax a copy
