Constant circulation
Joe Plumb
Member Posts: 7
Hi Dan,I had a recent conversation with a fellow member of the trade regarding constant circulation utilizing a constant but lower temperature. This method of heating came into play after I had mentioned the awful heat swing that occurs in my own home.Here's the situation. I,ve got old style recessed cast iron radiators on the first floor zone and they always overshoot the setpoint on the t-stat; at least by three degrees on really cold days. Yes, I have checked the heat anticipator setting. He mentioned installing a two stage t-stat and a mixing valve. Hot water is produced by the boiler and circulated into an aquabooster requiring the boiler to maintain temperature. Given this, what would you suggest as an efficient setup incorperating constant circulation? (controls, mixing valve, etc.)
a different Dan
What we've been doing is piping the boiler as a secondary and "feeding" into the constant circulation of the CI loop. Your alternate load of the DHW tank doesn't need to have any effect on the space heating flows or temperatures. This strategy also allows for the use of WWSD and full reset of the radiator primary. Enjoy....Dan
and the other dan
dan h. will be out of town till next week, he told me to tell you.0 -
A small band aid
Maybe you could try wirsbo's New digital t-stat, has a -1 degree dif.0 -
TRVs
(Thermostatic radiator valves) May be difficult with recessed convectors (like requiring in-line valves below the rads) but with constant circulation and TRVs, space temperature fluctuation is near nil.0 -
what would ..
you use (make/model) to control the boiler and water temp in a constant circ. system? If it were your house?0 -
a couple of options
tekmar 256 or 260, Honeywell AQ475A
Mark0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
