Thermostat Recommendation
Drod
Member Posts: 59
What thermostat do you recommend for a single pipe, low pressure steam system having two loops and serving a 2 story w/basement residence?
what do you...
want it to do ? Just temperature.... the honeywell t87 are ok. Programmable the LUX brand do a decent job. But if you want to go al out a Honeywell cronotherm is tops. What is even more important is placement. This will help keep the whole house balanced.Not behind a door or near a heat/ cold source not where the sun will hit it ,etc.,etc. I hope this is what you were looking for.kpc0
- 87.4K THE MAIN WALL
