Tooting my own horn.............again ;-) (hb)
heatboy
Member Posts: 1,468
"Find a Contractor" advertisement. What fun this project was!
http://www.unicosystem.com/Pdfs/Farmhouse.pdf
Warm Regards,
heatboy / climatecadvanced.com
"Expert in Silent Warmth"
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=103&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Warm Regards,
Interesting...
how you set the RN in the back rather than the front on the HoriCell. Do you use Viessmann's mounting bars?
Way to go heatboy
you're definitely gonna get some nice jobs out of that fine job you did. Mad Dog
Did you insulate the PVC plentum for the unico? If so , what with, If not, why not? Great work!0 -
The window..........
is just to the left of the boiler. If I had set the boiler in it's normal place, it would have covered the window. That, and the air handler, well tank and freezer are only 18" or so in front of the Horizontal indirect. Servicing of the boiler would have become problematic by moving the boiler towards the front. As you can see, the rear of the boiler is rather busy with all of the things going on back there, but in the end, it worked out just fine.
Thanks for the compliment. See you at "Wetstock".
hb
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"There was an error rendering this rich post.
Mother Earth.
Jim,
The ductwork is +12" under grade so there is no conventional insulation around it. Plenty of "R" with the ground. The first 2' after the discharge is lined to help quiet down the system. The short rigid sound attenuaters offered by Unico work suprising well considering their size.
Thanks for the compliment!
hb
- 120 Geothermal
- 394 Solar
