hot water monitoring devise
Jim Smith
Member Posts: 2
Does anyone have a idea who might make a hot water monitoring devise that can read temperatures on individual suplly lines in a multiple boiler, multiple zone heating system. The present system uses a Tekmar 254 control to control the boilers and supply temp but we need to monitor the separate supply lines and record the operating temperatures in the individual supply lines.
ISHTA
ISHTA is a German company with offices in NJ. They make flow meters and BTU meters. You can try a search for "BTU or Flow meters"
I've installed the ISHTA products. Expensive. If you're trying to log usage in an apartment, be prepared to spend more than the boiler for the monitoring equipment.
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
- 121.3K All Categories
- 84K THE MAIN WALL
- 2.9K A-C, Heat Pumps & Refrigeration
- 53 Biomass
- 417 Carbon Monoxide Awareness
- 40 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.8K Gas Heating
- 119 Geothermal
- 155 Indoor-Air Quality
- 3K Oil Heating
- 56 Pipe Deterioration
- 773 Plumbing
- 5.4K Radiant Heating
- 362 Solar
- 14K Strictly Steam
- 3K Thermostats and Controls
- 51 Water Quality
- 38 Industry Classes
- 73 Job Opportunities
- 19 Recall Announcements
