Say HR, Older GV's
Boilerpro
Member Posts: 410
On the older GV I've seen, The hoffman mixer is only provides partial mixing, It was hooked up onto a separate 3/4 inch connection. I don't believe it was intended to provide full protection....I think the instructions still required either by pass piping or a return mixing valve, but it has been awhile since I l ooked at it or talked to the techs. I believe it chief intention was to allow the boiler to warm up quickly in typical baseboard systems. You may want to double check this. I'm sure you don't want any of your boilers looking like theGV Glenn Stanton has a picture of. I believe it is a picture of a GV that was installed in a gravity conversion without external protection.
Boilerpro
Boilerpro
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 962 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 44 Industry Classes
