Oldest house Ive worked in
that are 30 years old or less . The bigger part of this house was built in 1817 . This one is in Wading River , overlooking the failed nuclear power plant . Roundtrip from the shop was 106 miles . Oh , and then there is a boiler.
  • Big one
    I forget the name on this 6 section , but it had a green cloverleaf on the front .
  • The lady of the house
    is in her 90s , and only uses the newer part of the house , only 6 radiators are connected . There used to be 16 . We put in a 3/4 bypass , just in case .
  • chuck shaw
    chuck shaw Member Posts: 584
    how did it
    feel to have some room to work?
    looks real nice
    Chuck
  • Not good
    The floor in the boilerroom was all dirt and cement , no good , level spot to put the boiler on at all. So we used the solid blocks . And getting into the boilerroom was even better - the wood floor was rotted out , so we had to bring a piece of 3/4 plywood . We still fell through in one spot . Thank you Chuck .
    Steamhead Member Posts: 17,735
    Ron, I think that was an old Ideal
    made by American Radiator Co. Thye used to put the four-leaf clover on many of their boilers. Hard to tell from the photo which model it was.
    And the replacement job is beautiful, too.
    Consulting
  • Man , youre good
    Yes , it was an Ideal . After you said it , I remembered seeing the nameplate . Very good eyes , Steamhead . I should remember it though . Ive ripped out 1500+ cast iron boilers , and can probably name only 3 or 4 brands just by looking at them . Thanks for the compliment .
