Electric Boilers
Doug_2
Member Posts: 14
....and running it isn't cheap. But, the water's always there and hot, there's no sound, and best of all (for our place) there's no venting issue. We're intrigued about the possibility of using an electric boiler to handle our hot water radiators. Does anyone have any experience with these units? Any brand recs? Or is this something like electric baseboard that nobody uses anymore?
Try Slant/Fin
Just sold another one yesterday - for a 5000 sq. ft. commercial app. Owner's choice.
Electric boilers are designed for closed loop application - water heaters are not - so longevity and recovery rate are your two big plusses. There are very few conditions where you would expect any energy savings by switching out one to the other. 1KW=3512BTU. Locally our electric rates are low by most comparisons - about 9 cents (CDN) per KW making it currently competative with propane. No chimneys, no combustion just a huge wire to drive them. Enjoy.....Dan
Elec. boilers
Argo is another manufacturer that we have used in the past. You need a good flow to keep the elements from burning out. That is the only caution I will give. The wire size is usually bigger than the copper pipe connected to the boiler. Leave enough room to connect large wire to the unit. Large wire doesn't bend too easily. Good heatin.0 -
Ele. heat
Why don't you install a oil fired boiler for both heat and hot water? This will give you plenty of both and alot cheaper to run. Thier are direct vent oil boilers that vent like a dryer vent.Customers will have a very short pay back over electric usually. Just thinking out loud.0 -
Should be clear, we are the HO's, and currently side vent with a Field PVO with great success. It's just that before we take the leap to formalize our situation, (move the boiler to permanent location next to sidewall, buy and install new oil tank, and abandon good electric HW heater/purchase and install indirect HW tank), just wanted to make sure we hadn't overlooked and easier option. Truth be told, would go with gas but it gives my wife the jitters and Dunkirk's Q90 with bigger sizes is still a year away. P.S. Do any of Viessmann's gas boilers side vent with PVC like the Dunkirk? Can't tell from the website and have some calls in to the local reps. Hopefully, will hear back this week.0 -
If you can get gas past the comittee....
Viessmann's new Vitodens is a beautiful and extremely efficient direct vent condensing boiler. It's even priced within the reach of most projects. Certainly worth a look! Enjoy......Dan
You're right. Only problem is, can't tell from flyer or technical data what the venting material is pvc or not.0 -
One of my Customers
had an electric boiler and I took it out because they couldn't stand the noise?
(The Meter hum)
jcg
The Vitodens
> is pvc or not.
The Vitodens
will not vent in pvc. Viessmann has their own vent, its a concentric vent, the inside vent or exhaust is plastic but it is not a pvc or plexivent type material. For the Plumbers out there it is more like acid waste piping, it feels like orion acid waste. Maybe some type of polyproplene. Plan on a 5" or 6" OD for their vent.
gib0 -
Another wall hung gas............
boiler that vents in CPVC and is now in theprocess of changing to sch.forty PVC is the MZ boiler.The Monitor........www.mzboiler.com.
cheese0 -
Saw "polypropyline" in reference to the VM venting and thought, "will that look like white plastic?" Their website refers to separate instructions regarding Viessmann's own propietary side venting system--but these don't appear to be available online/pdf. Will find out this week, no doubt. Thanks, gib.0 -
Saw it on the web. White pvc venting would work out well for us, but it's hard to believe these wall hung units produce enough heat to handle hw radiators (14 of various size) for a 2100 sq ft house and the dhw for an indirect to boot. You would think more and more HO's would switch to them if they did. Maybe they are or should be. Thanks for the tip.0 -
electric boilerz ??
Doug, you said the elec. hwh was expensive to run, so ??? would you want to use elec for heat? Do you have $$$ to burn? You can send any $$$ you don't need/want to me. Seriously though, something about water and elec mixing together that I never did like. Must be an ole fashioned fart. Here in NYC elec is expensive as hell, no one uses it here. Modern oil and gas boilers can't be beat for e-fish-n-c (Sometimes I have to get phonetic)and w/ a hot water system, you'll put it in only once a lifetime.0 -
Don't have $$$ to burn. But, we have a few logistical problems with oil (ie. tank replacement and relocation to a smaller utility room in the basement) and my wife worries about gas. Need to side vent, too, preferably in white pvc, or something that can be painted white. So, just wanted to rule out electricity before going forward with fossil fuel. Based on what I've read here this (rainy) weekend, we'll take a closer look at the Monitors and Viessmanns for oil and gas next week.0 -
NY Thermal
NY Thermal makes a similar wallhung boiler to the Vitodens capable of 120,000 Btu's, fully modulating, called the Trinity. It also comes with domestic water heating as an option. The nice thing about it is that it uses ABS plastic venting. It is very similar to the Vitodens as it actually contains many of the same components which both companies buy from the same place. But with NY, you are not paying for the grey paint on the outside like you would for the Viesmmann. Check it out at:
http://www.nythermal.com/Products/boilers/gas/trinity.htm0 -
I checked out the Trinity. Pretty amazing. We don't have a hot tub or anything, and we're a small family, but do take lots of showers and baths, do lots of laundry, and there's a daily dishwasher run. Yet, this boiler claims to provide dhw, too, without a tank? All this, and run 14 radiators, too? We'll have to see. Saw the spec allows for pvc, too. I assume that boilers using pvc these days don't share the problems of those subject to the recalls we see all over the web. Anyone ever installed one of these?0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 5.7K Gas Heating
- 110 Geothermal
- 161 Indoor-Air Quality
- 70 Pipe Deterioration
- 999 Plumbing
- 6.3K Radiant Heating
- 391 Solar
- 15.4K Strictly Steam
- 55 Water Quality
- 45 Industry Classes
- 48 Job Opportunities
