Question for Dana Z.
Ingvar
Member Posts: 5
Thank you Dana, for responding to my earlier question. You mentioned adding mass to the system with a buffer tank.
How exactly is a buffer tank set up in a one circulator four zone system?
Sorry for intruding,
but John Siegenthaler has written an excellent article on the use of a buffer tank; you can read his article at:
http://www.pmmag.com/CDA/ArticleInformation/features/BNP__Features__Item/0,2379,78589,00.html
The system he describes uses a specific kind of buffer tank; it's actually an indirect water heater, but one that uses the coil for domestic hot water and the tank for boiler water instead of visa versa.
Thanks Alan!
Ingvar,
Please refer to the article that Alan referred to. It is good, albeit depicting a fairly intricate system. I 've developed a pretty strong understanding of the concepts, but there are folks on the "Wall" that have much more "real" experience and they deserve the credit for the ideas. I think Hotrod has worked with adding system mass quite a bit. You may need to repipe and add a primary loop circulator, depending on how your system is set up now. What you describe suggests a possible scenerio for short-cycling - maybe only one of the four zones calling for heat at a time and then achieving the target temp with a short burn. Maybe some of the other folks have recommendations for how zones might be controlled to address your concern.
Best Regards
Dana Zaichkin
( A homeowner and weekend radiant wannabe)0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
