Staple up?
Bill Clinton
Bill Clinton Member Posts: 75
Just read an article by John Siegenthaler on the subject and that, coupled with the discussion on Kitec staple up below leads me to pose the following question:
Is it ever a good idea to use staples to attach to the underside of the floor or to joists?
While I think its fine to staple onto the top of the floor and immobilise the tube with a gyp/concrete pour, stapling tube to the underside of the floor leaves the weight of that tube hanging on a very small bearing area, and temperature changes make that tube expand, contract,wiggle, migrate, and scrape: Thats in the nature of the stuff, particularly regular old non Kitec pex.
To me, use of actual staples in a "staple up" system looks like a very bad idea. Loose fitting full circle clamps, yes. Staples no.
Seems to me this is worth a discussion.
Bill
billyboy
  • Dan Foley1
    Dan Foley1 Member Posts: 55
    Staple up
    On my "staple up" jobs, I use galvanized emt straps and 3/4" zip screws. This holds the tubing tight to the subfloor and has a fairly wide contact area to avoid rubbing through the pipe. I have used this mainly with rubber tube although I also use the straps on pex/extruded plate jobs between the plates and at the return bends. I agree that staples are probably not the best way to attach pex to the bottom of the subfloor. -DF
