Hot Water Loop on Steam system
How do you fellows do a hot water loop off a steam boiler? Do you add the hydronic heat loss to the radiation(steam heat loss) to size the boiler? I will probably use an Everhot tank for the heat exchange - simply fire both circulators at the call of the hydronic thermostat? Do you install any type of flush or cleanout fitting on the boiler water side of the heat exchanger? If the hydronic heat loss is much greater than the steam heat loss do you limit the circulator with an aquastat? Your thoughts are appreciated, Rich
