Hot water circulating system
Dan Peel
Member Posts: 431
Here's the web site.
http://www.wattstopper.com
Dan
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=174&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Dan
Engineered plans
I'm just looking at a set of plans that calls out a hot water circulating system; the circulator is wired to a Taco SR501 single zone pump relay with the T-T contacts wired to a motion sensor in the bathroom. The manufacturer is listed as Wattstopper; has an adjustable delay on break relay or switch in it so you can control how long to keep the circulator on.
What a brilliant way to control the circulator!!
Anybody ever use one of these?
Sven, can you give us a link to Wattstopper?
All the best,
Alan
Not exactly, but I did use motion sensors in a dentists office to activate pumps for the rad panels in the exam rooms. We set it up so that the pumps would shut down after 2 minutes if no motion was detected.
I'll have to remember this one.
Thanks Alan!!!!!
Mark H
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 5.6K Gas Heating
- 105 Geothermal
- 69 Pipe Deterioration
- 959 Plumbing
- 6.3K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
