Alternatives to copper tubing- S.D.
S.D.
Member Posts: 13
Does anyone know anything about using "rubber hose" as opposed to copper tubing in the walls and ceiling on circuit loop systems, I've seen it in a few houses but I can't find any info. on it. I would be interested in the cost over labor and also adapters and how they fair against corosion. The hose I've been seeing is yellow and adapts to 3/4 cop.
Pex
I don't know anything about rubber hose for heat loops,but we do use pex and pex-al-pex for that durpose.The labor savings is huge.Just be carefull of the large expansion rate with pex.
rubber hose
heatway onix looks alot like rubber hose and i've seen it used as describbed, i personally use pex like john
chris smith0 -
PEX
For PEX information see;
http://www.heatinghelp.com/newsletter.cfm?Id=18
Rubber is perishable, and PEX isn't.0
