Snow melt with injection mix hot rod
hr
Member Posts: 6,106
at a commercial building. A Raypak Hi Delta sealed combustion hanging. The Grundfos Mixi Miser was a snap to install and interface with the tekmar snow sensor.
The manifold is in a planter bed next to the walk with a cement block and 4X4 pt frame with a piece of 1/4" diamond plate cover, in John Deere green!
These Jomar strainer ball valves are a nice feature for initial purge and cleaner, then as an isolation valve. I removed the small filter when the glycol/ DI fluid was added.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
hot rod
