Vitodens- Mike Norgan
We just started this project on wednesday. The Vitodens will be heating a small lap pool and some radiant around the pool.
  • Mike Kraft
    Mike Kraft Posts: 406
    Mike
    How about some shots of the works?The technology that we're getting bombarded with is incredible.The Vitoden .....is capable of 25K to 250K.....fully modulating correct??
    How many have you installed?
    cheese
  • kf_2
    kf_2 Posts: 118
    VITODENS
    Mike,
    Actually there are 4 sizes:
    WB2 6-24 = 25-91 MBH
    WB2 8-32 = 37-124 MBH
    WB2 11-44 = 55-172 MBH
    WB2 15-60 = 80-230 MBH
    they all have fully modulating gas valves as well as modulating vent fans and the smallest unit has an integral, fully modulating boiler pump.
    kf
  • Paul Pollets
    Paul Pollets Posts: 3,672
    Nice!!
    Post some completed pics when you're done. Let us know how the startup and controls go for you. How about the condensate neutralizer?
    Have you used the Maxi-Flo HX before? I've had pinhole leaks at the welds on each end. I was suspect to spec it again after having 3 succesive leakers on the same project. The company made good, but I felt the leaks should gave been discovered in testing prior to shiping. It created a very embarassing moment for my previous company, after touting the product. Oh Well. It happens sometimes.
  • hr
    hr Posts: 6,106
    Is that 24 karat gold
    lettering on the boiler? Or just the way the light strikes it :) Tell us how she fires and performs, when you get to that point.
    hot rod
  • 24 karat gold
    Hot Rod,
    I think I just forgot to remove a sticker from the boiler. I will post pictures of the final install when everthing is up and running.
    Mike Norgan
