The free heat loss calc, can it also be used for - cmbb.....
radiant heating with warmboard type panels under a laminate Pergo type floor?
The free heat loss calcs, can it also be used for...
radiant heating with warmboard type panels under a laminate Pergo type floor? Will it be accurate?0 -
Heat Calc
Yes, Heat loss is seperate from what your asking. It will not show how much heat will get through the floor covering. That should be a small seperate calculation on your part. Treat it as a seperate surface, and calculate the heat transfer through it. The more covering (insulation) the harded it is to heat. R values of the wood,pergo, carpet and other coverings should add up. Remember the conduction value of any covering is equal to the recripical of the R value. Hope this helps.0
