Boiler delta T
Eric
Eric Member Posts: 95
Where boiler load is mainly radiant are any of you sizing the primary flow for a lower delta T (ie 10-15) instead of 20 degrees to provide for more mixing tempering of the cooler secondary water with primary boiler water?
