Z-Vent - nick z.
nick z.
Member Posts: 157
Doing my first power vented gas boiler (W-M) Using Z vent for the outlet. The Boiler came with a wall kit for the outside which is for both inlet and out let. The problem is, when I drilled the hole for the fresh air inlet as it need to be using the kit with the boiler, I damaged the Z vent wall thimble as it protruded into the path of the inlet.Any way around this? I will call Z- vent in the morning.
